Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (WE b OLD, JW51, 55shaker, Woodcmiami, Ponchogl, NorCal52Suburban), 577 guests, and 2 robots.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
Hi All,
I bolted the torque tube to transmission this weekend on my 1940 Chevy 1/2 ton pickup with 216. After getting it put together, I noticed a hairline crack at the rear, top of the transmission-see attached pic. I am unsure if this happened upon assembly or if it was there previously. I did not notice it when I had it on the stand. What is the recommended repair method? Brazing or other? Also, is this common? Has anyone seen this before?
Thanks for the assist.
Have not seen a crack in that place, but the preferred repair method would be to drill a hole at the end of the crack to stop it from continuing. That spot could probably be brazed, or you could install a series of plugs along the crack. Here's an outfit that does cast iron crack repair and sell DIY kits. Link
That crack isn't in a real high stress area, so once the crack is stop-drilled, you could probably use something like JB-Weld. The issue there would be to get it absolutely spotless so the crack gets sealed. That might be the best approach so you don't have to mess with refinishing the area where the u-joint ball sits.
Crusing in the Passing Lane
Old Scotchman,
There are lots of people getting rid of torque tube drive lines, I’ll bet many have that part lurking somewhere in the dark they would be glad to give you one.
Ed
Thanks Kevin and Ed for the comments. I will stop-drill the crack and try JB Weld.
I would die grind, out the crack into a V .Drill hole at end of crack then fill.
https://www.muggyweld.com/
this melts at very low heat and is super strong and can be filed smooth. I have used this with great success,on many cracks ,and it has never re cracked . Applies like solder, flows into crack perfectly.
!956 Gmc Napco 4x4 Factory line built .
I would be very tempted to leave well enough alone...............don’t think it going to a problem in the near future ( next 20 years).
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.052s Queries: 15 (0.049s) Memory: 0.6162 MB (Peak: 0.6824 MB) Data Comp: Zlib Server Time: 2025-09-22 14:05:34 UTC
Valid HTML 5 and Valid CSS
