6 members (carbking, Charles in CA, TooMany2count, 1955 1 Series, Donf, FAST55), 344 guests, and 5 robots.
Topics128,160
Posts1,057,054
Members48,463
41 1 1/2 ton dump truck. 216 w/rochester.While revving engine there is a stumble or cough before getting up to rpm.Carb seams to be in order,viewed all Mikes Carburator vids every thing checks out. Maybe I dont know how to tune it correctly. Points look good, coil tested ok,Vacum advance functions with vacum test,although sort of sticky,plugs look good. Certainly confused.Any help would be appreciated. Thanks
I has a similar issue on a 235, adjusting valves and advancing the timing was the fixed it for me.
Just a couple of many things to check. But other will be along with more suggestions.
Shop manual a big help for initial timing
Good luck
M Online: Happy
Swap out the condensor. Been working with that subject recently and if you have one that’s less than perfect, a good one makes a big improvement.
RR
RonR
1970 340 Duster
1964 CJ5
In my experience, when my 261 was coughing and backfiring, it was because the timing was set too lean.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
If the vacum advance is sort of sticky I would clean that and make it not sortof sticky and see what happens.
Tommy
59 apache 1/2t
261 short stepside
