6 members (Donf, Gray_Ghost, Peggy M, SWEET, mvigo, rfs56trk), 48 guests, and 3 robots.
Topics128,023
Posts1,055,367
Members48,420
#1386430 11/29/2020 6:39 PM
Hi all, i have a 1958 viking 60. Im looking for the axle nut socket for the rear end, 2 ton chevrolet corporate 2 spd rear. Thanks!!
THE BLACK VIKING
1958 Viking 60 ~ my new toy hauler
My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60
Keep 'em rollin fellas!
!956 Gmc Napco 4x4 Factory line built .
Once you confirm your size you can look for a used one on the big auction site...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
My trick was to use a short pipe nipple and weld pieces of 1/4" key stock onto it to fit the slots in the nut. Either drill a hole in the pipe for a long punch as a handle, or just use a pipe wrench.
Measure the diameter of the nut, head down to the hardware store and grab a hole saw bit the same size. I ground down a 3.5" bit and notched it out to match the nut on my 67 c50 15klb 2 speed rear. Worked like a charm.
Hold the bit down flat against a 4.5" angle grinder disc to get rid of the teeth and then notch from there.
Edit: Be safe and use a buddy to hold the grinder while you hold the bit! Safety glasses gloves etc
Moderated by  MNSmith
