3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
Curmudgeon
Curmudgeon
I believe I spotted an error in a website's procedure to rebuild a Rochester B, BC, BV.
Would someone please look at the attachment and verify?
It is so easy to make a mistake.
2 Offline
The photo that’s says correct is good
Don’t block the tiny hole
That’s how I find them when I disassemble for rebuild
I’ve rebuild two of these this last summer
-s
Curmudgeon
Curmudgeon
Thanks for responding.
I sent a message to the website advising of the error.
I'm slowly learning that there is much more to rebuilding a carburetor than reading step by step instructions.
