2 members (latroca52 , 1 invisible),
131
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,196
Posts1,057,388
Members48,471
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Saw this tachometer on eBay Post implies original equipment Photos aren’t the best Is this an original part for a 1953 truck? https://www.ebay.com/itm/1947-1953-GMC-Truck-0-3500-RPM-Tachometer/124450092248?hash=item1cf9cdb4d8:g:yZYAAOSwaspfuBPu Not sure I want to pay that much to find out But it looks neato -s
Curmudgeon
Curmudgeon
Oh Cool! Wild guess maybe an original commercial diesel truck like the 630? It's driven by a cable so maybe it was connected to the distributor or the generator. I could only find an example from a 1957 GMC 630.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
the low rpm range certainly suggests a diesel.
Agree it's in diesel rpm range. But could also be stovebolt range. Isn't 3000-3500 the working range for a stovebolt engine?
RR
RonR 1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
thats the useful rpm range for sure, but if i recall correctly the redline for a 6-cyl of that era is around 4200. i figure the tach for a gasoline stovebolt would run up to 4500. but i'm speculating.
Curmudgeon
Curmudgeon
Crusing in the Passing Lane
My 630 has a dash mount location for one. Ed
Curmudgeon
Curmudgeon
The seller said he bought a group of parts to get the parts he wanted.
I recall reading that a 216 engine redlined somewhere around 3,200 and a full pressure 235/261 redlined somewhere around 3,800-4,200, but can't seem to put my fingers on that documentation. I never hesitate to put the gas pedal down hard on my 261 in traffic, but I highly doubt I have ever exceeded 3,000 rpms with it.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
