| | | Forums66 Topics128,156 Posts1,057,018 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | 41 1 1/2 ton dump truck. 216 w/rochester.While revving engine there is a stumble or cough before getting up to rpm.Carb seams to be in order,viewed all Mikes Carburator vids every thing checks out. Maybe I dont know how to tune it correctly. Points look good, coil tested ok,Vacum advance functions with vacum test,although sort of sticky,plugs look good. Certainly confused.Any help would be appreciated. Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I has a similar issue on a 235, adjusting valves and advancing the timing was the fixed it for me.
Just a couple of many things to check. But other will be along with more suggestions.
Shop manual a big help for initial timing
Good luck | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Swap out the condensor. Been working with that subject recently and if you have one that’s less than perfect, a good one makes a big improvement.
RR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | In my experience, when my 261 was coughing and backfiring, it was because the timing was set too lean.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If the vacum advance is sort of sticky I would clean that and make it not sortof sticky and see what happens.
Tommy 59 apache 1/2t 261 short stepside | | |
