| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | I'm considering installing a vacuum gage on a factory carbureted 261 . Where should I hook the vacuum hose , would branching of the P.C.V line work ??
good planning is no substitute for dumb luck
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Anywhere that gets full manifold vacuum would be a good choice. Don't use the ported vacuum that goes to the distributor. The port on the side of the manifold where the vacuum wiper hose attaches would be good, or a T fitting at the manifold side of the PCV would work well. Jerry
