2 members (NJC, Cosmo), 61 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1385608 11/23/2020 5:41 PM
We have made great progress on my friend’s 3100. The painted truck is fully assembled and runs well.
The one major item left is wheels and tires. I have done quite a few searches. Obviously there are lots of ideas and opinions about bias or radial, classic or modern, tubes or tubeless, etc. The owner’s preference is to run a set of modern radial tires on the stock wheels.
The original 6.00 x 16 tire has about 6.8” section width. That translates to about 175 mm. The limitation is that there are almost no 16” tires in that width range. The few that I can find do not have enough land capacity and are too small in diameter. One other limitation we have is that we cannot handle much if any diameter increase due to the garage door height.
From a practical standpoint how wide a modern radial tire can be used on the standard 16x4 wheel? My concern is the distortion of the tire profile and crowning of the tread due to the narrow bead width.
Rusty
Do you know what year the wheel is for/from?
The 1954 16" rims are 4.5" x 16"
Cooper Tire SRM II LT215/85R16 black truck radials on my Suburban.
A 215/85R16 Radial will work well on a 4.5" wheel/rim.
I forgot that detail in my original post. This is a 1949 3100 so the rims are 16x4. I cannot remember if they changed to 4 1/2" in 1950 or 1951.
Rusty
Insomniac
Insomniac
Did you try Coker tire? Expensive, but if you must keep your old rims...
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Hi Gord,
I agree that the owner might have to adjust expectations. The solutions are to either get different wheels or pay for tires from a source like Coker.
From my perspective I would definitely be concerned using anything wider than a 205 on a 4" rim. 195 is really the maximum I prefer.
I have a friend running 225/70 -16's on 4 1/2" rims on a '54 3100. They do bulge quite a bit. I agree with the match between your 215/85 on a 4 1/2" rim.
Rusty
I just found a tire on Tire Rack that's pretty close to a 600-16 (185mm wide) that would probably work on a 4" wide wheel. They do caution that it's a summer only tire and shouldn't be driven at freezing temperatures, because the compound can crack. To me that would be a definite no-go, but may be an option for guys in warmer climates like SoCal, Texas or other southern states.
Link
Insomniac
Insomniac
Kevin,
In the specs for the tire you linked, they recommend 5 to 6.5 in wide rims. Don't know what happens if the tires are installed on rims outside the recommended range. Even if they work OK, could some lawyer make an issue of it in case of an accident?
Gord 🇨🇦
Originally Posted by Gord&Fran
Kevin,
Hey, some lawyer would probably make an issue of it even if they were on the right width wheels. ohwell
The 215/85R16 size that Tim mentioned would have the same issue. Other than the Coker 600-16's, there are no modern tire sizes that I can find that are recommended to fit on 4" or 4.5" wide wheels.
H Online: Content
The old rule of thumb used to be to run a wheel width that was 75%-80% as wide as the tire footprint. On a metric radial that would make a 195/85R16 about the right size. A 215MM footprint would be 20MM (just under an inch) wider than optimum. That's not way off, but it might result in an oddball wear pattern of the tread.
That tire I posted costs as much or more than some of Coker's offerings, so another strike against it, at least for me.
Great inputs and ideas. I appreciate the confirmation that we need to proceed carefully.
I saw the data that shows 3 different rim widths for 3100 trucks in 1949. I will confirm that we do have the 4” rims. There are very old 6.00 x 16 tires on it currently.
Rusty
Last weekend I confirmed that the rims for this truck are the base 16x4" wheels. We are going to get them sandblasted tomorrow so that Steve, the truck owner, can paint them.
We are considering tires with either a 195 or no more than a 205 section width and in a higher profile (minimum 75 aspect ratio). I am concerned that a 215 section is just too much for a 4" wheel. We should be able to find a tire that has an acceptable diameter and load rating within those parameters.
Thanks for all the help.
Rusty
We installed General Grabber HD 195/70 - 16 tires on the 4" rims. We would have preferred a 185 section tire but could not find one with a reasonable outside diameter that would fill the opening in the fenders.
There is some crown to the tread and the sidewall bulge is more noticeable than you normally see. It could be an issue on a truck that would see lots of highway miles.
We are pleased with the results and feel they will work great for Steve, the owner.
If we could find an inexpensive set of 4 1/2" rims we would consider swapping the tires to them. That extra 12 mm of wheel width would improve the fit quite a bit.
Thanks for the help.
Rusty
