| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2020 Posts: 3 Moderated | | Moderated Joined: Aug 2020 Posts: 3 | Looking for someone that has knowledge, information, parts And etc. On a 1950 chevy Big truck. Big as in a 2 ton. It's all apart. This is a different animal. Everything on this truck is different than the pickup or 1 ton. Except for the cab. All the frontend sheet metal is different. And I'm lucky in that I have most of the front end sheet metal. Doors, hood fenders, etc. And it's in good shape. But what I am missing is the grill. Now I know the grill looks the same as a pickup. But it's different also. So here are my thoughts and questions Since I do not have a grill at all. Can I modify a pickup grill to fit the 2 ton. I'm sure the 2-ton grill is taller than the pickup grill. But think it's the same width. But not sure. Does anyone know for sure if I can modify a pickup grill to fit the 2 ton by replacing the pickup brackets with 2-ton brackets making the grill taller? > I know it may sound crazy, but nowadays whatever works. I'm not in a hurry, I have the truck apart. But if the weather holds out, plans are for getting it back together soon So I am kinda looking ahead for parts and information. Thanks for any info you may offer. | | | | | Joined: Sep 2010 Posts: 2,333 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,333 | There should be a few two ton grills around either in a old junk yard or on someone’s property if you look around . | | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | I have a whole 2 ton clip you could have here in Philadelphia. All I want out of it are the headlight buckets. Come and get it. Fenders, grille, inner fenders, runing boards, hydrovac, heck I have the whole frame too. All I bought it for is the cab.
PS - this should not be a 1-ton post....... 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | You shouldn't have too much trouble sourcing what you need -- Help yourself to our free Classified Ads section -- the "Swap Meet" in the menu bar at the top of this page). Usually, it's the other way around -- little truck guys who are only finding Big Bolt front clips ...
You might also take a look at our Tech Tips (menu bar at the top of this page). There might be some info there you *might* find useful as it pertains to the bigger trucks.
Welcome aboard!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | As mentioned 1 1/2, & 2 ton 47-53 Chevrolet grilles, not too hard to find. I've seen a few on ebay, and on the 47-54 GM Truck Facebook group pages recently. | | | | | Joined: May 2015 Posts: 11,159 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,159 | I'd agree that big bolt stuff is easier to find around here. You may have to buy or haul away the entire truck, but they're out there.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2020 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2020 Posts: 43 | Amtrakjoe, do you have a two ton front clip, minus headlight buckets, to sell? And/ or a frame? Tried a private message which didn't work (?). Thanks. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | please keep all buying/selling in private messages. | | |
