7 members (baldeagle, Phak1, 66flea, Gray_Ghost, 2-Ton, 2 invisible), 49 guests, and 7 robots.
Topics128,020
Posts1,055,345
Members48,420
#13855 11/11/2002 3:19 AM
Is there a forum where I can get some addvice on a 1964 (chevrolet)chevelle rebuild? thanks Bill
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
#13856 11/11/2002 3:54 AM
I'm helping my brother do a frame off rebuild on a 1965 Chevelle....maybe I can answer your question.
If not, you can post here www.chevytalk.com/
Joe
#13857 11/11/2002 6:27 AM
What part are you rebuilding?
#13858 11/11/2002 3:23 PM
Check out www.chevelles.com
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#13859 11/12/2002 8:28 PM
Will try the chevy talk and chevelle .com
I have had no luck all summer on convertible top frame parts (front top bow), just finished the frame now for the sheet metal. then motor then interior then paint no end in sight. thanks for the help Bill
