1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#1385067 11/18/2020 3:01 PM
the rear end on my 53 1/2 ton 3100 is shot. Does anyone have recommendations on finding a replacement or upgrading to something like a Chevy S 10. Thanks, Scott
scottss60 #1385084 11/18/2020 5:40 PM
"Something like a Chevy S 10" is going to have a 5 lug wheel bolt pattern (unless it's from a 4x4) and require an open driveline which means a different transmission. There should be a lot of the closed drive line rear ends available from guys that made conversions.
Fred
scottss60 #1385086 11/18/2020 5:45 PM
What parts are "shot"?
Replacement parts might be available.
You could "upgrade" to a 3.55 Ring & Pinion set (from your 4.11) - check the Tech Tips, if you are interested.
And/or post a want ad in the Swap Meet for needed replacement parts.
rfs56trk #1385090 11/18/2020 6:30 PM
Originally Posted by rfs56trk
"Something like a Chevy S 10" is going to have a 5 lug wheel bolt pattern (unless it's from a 4x4) .
Fred
All S10 had 5 lug wheels
BC
1960 C60 pasture art
scottss60 #1385115 11/18/2020 10:38 PM
I guess I was thinking of later C10's & 1500's, thanks.
Fred
tclederman #1385118 11/18/2020 11:00 PM
My trucks rear end is shot so I would like to do a complete replacement and am thinking of an upgrade. Beyond a Chevy S10 any others?
Thanks, Scott
scottss60 #1385185 11/19/2020 7:15 PM
Crusty Old Sarge
Crusty Old Sarge
The Chevy Trail Blazer has a 6 lug bolt pattern (metric) and was available in different gear ratios, 3.42, 3.73 and 4.10 in the SS model. The axel with is 58.5 inches and was standard with rear disc brakes.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
scottss60 #1385245 11/20/2020 12:37 AM
rad Offline
So if you want a 5 lug will a S 10 rear end fit?
scottss60 #1385538 11/22/2020 10:51 PM
Thank you to everyone that have responded. I have found a rear end from a 49 with a gear conversion of 3.55 that I will purchase.
scottss60 #1385956 11/26/2020 1:59 AM
Awesome for you. I put 3.55 gears in the Green Turd and cannot express enough, how much I enjoy those gears. You will enjoy them as well.
Craig
