7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have a 51 chevy 3/4 ton and am trying to find a rear sway bar. I bought one from Chassis Eng. but it is too wide (fits the 1/2 ton which has wider frame rails) and won't fit. My rear is a 10 bolt with a TCI leaf spring kit. Does anyone have a suggestion. (eng. 330 hp small block w/ 700R4 tranny)
~Jim
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | dont know if this will help or not.i remember reading in i think it was general truck talk. the topic was brought up.and somebody mentioned what they were using for sway bars.you might try a search and see if that brings it up.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | make it work if you have too. there is a way or http://www.energysuspension.com/pages/swaybbct.html http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=007420#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=007158#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=006630#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=002462#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=001007#000000 found mine in a framers field (dumb luck) i believe it's from a nissen or toyota. i had to make the links up myself. 4 wheel shop
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks guys. I'm still looking. Most talk here is for 3100s which will take a 39" bar. My frame is more like 35".
~Jim
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | FYI, if you find a bar that is close they can be cold bent in a hydralic press. The 39" bars that are referenced are out of a late 80s Camaro/Firebird. I cold bent mine to be about 36" wide at the eyes. This is so it will fit between the frame rails.
Here are two ideas for finding a bar. 1. Shops that build lowriders take out the sway bars and throw them in the scrap pile. There is a shop not far from where I work and the owner has let me go through the "scrap" a coulple of times. I once bought a bar from him for $10 and did not have to go to pick a part and take it out. 2. Spring shops are always changing springs and sway bars. Again the "scrap" is just piled up until it gets too big and taken to the scrap dealer.
Have fun with your build.
Lonnie | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | S10 Extreme rear bar is approx 31-1/2. If you need pics, I'm fitting one now. Let me know and I'll snap some. I got my bar on ebay with hardware. mv | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mike: It would be good if you could send some pics of what you're doing. It seems my problem stems from having to position the bar under the pumpkin which then interferes with the springs and shackles. I'll see if I can take a picture of this when my son gets home after while. It takes two to do that.
~Jim
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | I put three pictures at: http://www.enzoco.com/mike/bar/ I installed my bar so that it loops over the diff, but I still need to rig some end links. The clamps that attach the bar at the axle tubes appear to work pointing either up or down, allow you to install the bar either on top or bottom. Mike | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Mike: If your bar positioned over the rear will work then I believe I can make mine work as well. One question, how will you attach the eyes? It looks like they are supposed to bolt onto the springs. All sways I've seen bolt on the frame.
~Jim
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | They attach to the frame using these links that are shaped kinda like little steel dog-bones with rubber bushings at each end. Definitely to the frame, or the bar wouldn't function as intended. MIke | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | How about a stock factory bar off a 1/2 ton pickup that measures 36" between the eyes? I'm running one on my "other" truck....it's mounted to the top of the diff with the stock hardware and points to the rear so it doesn't interfere with anything. The eyes are horizontal.
The donor was an early 80's 1/2 ton FoMoCo. I'll add a pic to the "Just An Old Truck" album of my webshots if you want to check it out. Hope this helps.
Dave | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | The horizontal eye factor supports the more traditional swaybar end links. I like that. - MV | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ubetcha on the horizontal eyes.....I've fabricated links for both types and it lets you tune the suspensions a whole lot easier. I've made adjustable links for some 4 wheel drive applications with the vertical eyes and even a few that could be easily detached for off-road.
The thing that most folks don't realize, is that using both front and rear sway bars will dramatically improve the handling of even a 60 year old truck. Just no reason to have to use a grab-rail and tense up when approaching a corner!!!
Dave | | |
