0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1385009 11/17/2020 10:38 PM
Will a 54/55 truck bed fit on a 47/53 frame or is it easier to put a 47/53 bed on a 54/55 frame. I have a 54 bed and a 52 frame. Thanks for any help.
flattop49 #1385014 11/17/2020 11:00 PM
Later beds are deeper (floor is closer to the bottom of the sides), so I don't think you can put a 54/55 bed on an earlier frame. In 54, the frame hump over the axle was shorter to allow for the deeper bed. A 47/53 bed should fit on a later frame, but may need to have different spacer blocks - easy enough to do.
A quick call to Mar-K would confirm that. I'm sure they'd be happy to give you the correct scoop.
