6 members (tclederman, TexasJim50, baldeagle, Peggy M, cmayna, 49choptop), 112 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#1384649 11/15/2020 8:11 PM
Greetings,
I'm going to attempt a 4.11 rear swap into my 3/4ton based on the tech tip. I have this rear from a donor and I think it may have had the 'tag' indicating a 'locker' rear end. Based on the pic, is this the case?
[img]https://photos.app.goo.gl/XUWXxcK4wfM1PrxK7[/img]
[img]https://photos.app.goo.gl/EMdzA57MHzmZ65Jr6[/img]
If it is, is this still a good donor?
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Goach2 #1384651 11/15/2020 8:29 PM
The casting numbers you show won't tell you if it's a locker or not. Probably the only way you can know for sure is to pull the cover off and inspect.
Goach2 #1384654 11/15/2020 8:44 PM
It's sitting on my floor, but i don't know what I'm looking for. If it is a locker, is that a problem?
More images
Goach2 #1384657 11/15/2020 9:22 PM
A locker would work fine, just a preference. Most lockers are not that, but are "limited slip" with clutch packs behind the side gears that restrict the differential action. Once you pull the cover off, look thru the openings in the differential case for the clutch packs and possibly preload springs. If it's an open differential, there will just be spider gears (two or three, depending on the design), and the side gears connected to the axle shafts.
First pic is an example of limited slip differential.
Second is an open differential. Pics are generic that I got from the web.
Goach2 #1384673 11/15/2020 10:48 PM
Doesn't look like either of them...
[img]https://photos.app.goo.gl/4oTMQ9n17J2mFE65A[/img]
More images
Goach2 #1384678 11/15/2020 11:00 PM
I doubt that's a locker or limited slip differential. You can check by sticking an axle into one of the side gears and turning it. If it's an open differential, the pinion probably won't turn, but the opposite side gear will turn the opposite direction. If it's a limited slip, the pinion will turn if one axle is turned.
Goach2 #1384684 11/15/2020 11:24 PM
Yes, I believe that is a limited slip carrier. If the ring gear was turned 90 degrees where the clutch pack tabs were visible, it would be pretty obvious. That type has 4 spider gears, arranged in such a way that different axle speeds with power applied to the driveshaft makes the clutches try to engage and match the axle speeds to each other. You'll need to learn to "cost" around sharp turns, as applying throttle makes the vehicle try to "straighten out the turn".
Goach2 #1384687 11/15/2020 11:34 PM
Ok, I will try that out, but regardless all I care about are the 4.11s. My other question is; is it worth replacing a pinion seal in this now? It doesn't appear to have been leaking.
More images
Goach2 #1384688 11/15/2020 11:41 PM
More images
Goach2 #1384704 11/16/2020 12:43 AM
Look at the rectangular part just inboard of the axle gear teeth- - - - -I believe it's part of a multi-disc clutch pack like one I ran in a dirt track race car back in the 1970's. That one also had a fully enclosed carrier where the spider gears were not visible. Try inserting an axle shaft into one of the side gears and see if it can be turned without also rotating the ring gear- - - - -if it's a "locker" it will take a considerable amount of effort to make the axle turn with the ring and pinion blocked in some way, like holding the pinion flange in a vise. On an "open" rear end, the axle gear will turn easily.
Goach2 #1384723 11/16/2020 2:25 AM
Ok, I'll give that a try. In the meantime, what do we think about the pinion seal? Change it or leave it be?
More images
Goach2 #1384725 11/16/2020 2:38 AM
Unless it's showing visible signs of leakage, stains on the pinion housing, etc., I'd recommend leaving it alone. It's very easy to upset the pinion bearing preload and induce a hum or rapid bearing wear, chasing gremlins that probably don't exist.
Goach2 #1384937 11/17/2020 1:47 PM
Ok, another question about the tech article. Does gasket sealer go on both sides of all gaskets in the process? I'm assuming the answer is 'yes' since it doesn't specify.
More images
Goach2 #1384971 11/17/2020 5:51 PM
Gasket sealer is a crutch- - - -clean, straight flanges don't really need sealers to keep gaskets from leaking. If I use any at all, a brush-on liquid like Permatex Super 300 applied sparingly is usually my choice. Most people use way too much sealer, or the wrong type for the job at hand. Seeing gobs of RTV oozing out of a joint in all directions sort of screams "amateur" to anyone who makes a living fixing vehicles.
Goach2 #1384978 11/17/2020 6:19 PM
So perhaps just a 'lite' application on both sides? I will tell everyone I'm an amateur before they look....
More images
Goach2 #1384984 11/17/2020 7:06 PM
The gasket should seal without sealer. Heck, Chevy makes exhaust manifolds that are designed to bolt to the block without gaskets. That's a hostile environment that typically doesn't leak. The rear axle is a little less hostile.
Goach2 #1385032 11/18/2020 12:59 AM
Maybe just a light smear for good luck wink it is in rhe tech article, so I'm assuming it's the consensus.
More images
Goach2 #1385095 11/18/2020 6:58 PM
A smear wouldn't hurt. But you have to look at what you're working with. Is the same exact gasket material that was being used when that axle was built? Or is it the modern replacement. Sometimes the old techniques in the manual don't apply anymore.
BTW, somewhere I still have a roll of that old, super hard cardboard-y stuff they used to make gaskets out of.
MNSmith #1385368 11/21/2020 4:26 PM
Got the diff removed and cleaned up. Went to put the new gears in, which is a pita and ripped the gasket. New one's coming on Monday and I need a new u-joint as well. Going ok, but I had plans to drive it this weekend and I'm missing out!
More images
Goach2 #1385764 11/24/2020 8:51 PM
One of the nuts got a bit rounded when removing the u-bolts from the u-joint. Threads look pretty fine, does anyone know what size these are?
More images
Goach2 #1385772 11/24/2020 9:36 PM
Take one down to your FLAPS and get new u-bolt setups. They're pretty common and still available in the size you'll need.
Goach2 #1385832 11/25/2020 11:54 AM
You definitely scored on that rear. That’s definitely a real locker assembly. Those are even more rare than the 4.11’s itself. I wish mine had one for climbing my steep dirt driveway.
Goach2 #1386058 11/26/2020 7:23 PM
Ha, looks like I got lucky on that one... thanks BF!
More images
Goach2 #1386304 11/28/2020 4:45 PM
3 Flaps and no ubolts, I may have to reuse the old ones. They cleaned up good, just a little stripping starting on the outside of one of the nuts.
More images
Goach2 #1386310 11/28/2020 5:09 PM
No need to reuse U-bolts...I've bought from these folks and got fast shipping and a good price!
https://www.uboltsdirect.com/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Goach2 #1386945 12/03/2020 3:35 PM
Finally got the 4.11s installed. Still have to change the drive axle gaskets and get the rear cover back on, but that's the easy part wink
[img]https://www.stovebolt.com/ubbthread...umber/25231/filename/20201202_203457.jpg[/img]
Still can't find these ubolts anywhere, I may be stuck with the old ones, which are in good shape, so might not be horrible...
[img]https://www.stovebolt.com/ubbthread...ad/Number/25232/filename/20201202_151607 (1).jpg[/img]
More images
Goach2 #1386949 12/03/2020 4:12 PM
Grade 8 nuts are available by the thousands on Ebay, and also at any good hardware store. What's with the obsession about replacing good-condition U bolts with no thread damage? Those are fine threads, either 5/16-24 or maybe 3/8-24. What size wrench fits the nut? If it's a 1/2" wrench, the thread is 5/16. If the wrench size is 9/16", you need a 3/8" nut. Just replace the nuts, not the U bolts!
Goach2 #1386954 12/03/2020 4:53 PM
Agree with Jerry. Odds are anything you might find will not be up to OEM quality on u-bolts. And "if" I needed to use the nut show with the rounded shoulder, and "if" I could turn it with a 6 pt. socket I wouldn't let that keep me from driving. That said, first choice would be to replace any less than perfect nuts.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
Goach2 #1386956 12/03/2020 4:56 PM
Google 1350 u joint u bolts. They're all over. Including amazon
1949 gmc 1-ton
Goach2 #1387126 12/05/2020 5:30 AM
Got me some grade 8 nuts and lockwashers and finished her off tonight. Got to take her up and down the road and it was awesome. I actually used first gear to pull out of the garage and it was noticibly better. Looking forward to taking it out tomorrow for a run down the highway 😀
More images
Goach2 #1387189 12/05/2020 8:47 PM
Definitely faster, 3rd is so much more comfortable to downshift into. Have to get a good app for speedo but is there anyway to change the speedo gears and get it somewhat accurate again?
More images
Goach2 #1387193 12/05/2020 9:07 PM
I use a Garmin GPS for a speedometer since I changed the tire size on my road trip truck- - - -resulting in a better cruise RPM with less toggling in and out of torque converter lockup constantly. That gave me about a 5% speedometer error, indicating faster than actual road speed MPH on the speedo. There are correction gearboxes made to alter speedometer cable rotation speed to account for different tire sizes, 2-speed rear axles, etc. Also, some transmissions can be fitted with different-size speedo drive gears, using an offset-center gear carrier that can be rotated to accommodate speedo cable drive gears with different numbers of teeth.
Goach2 #1399018 02/26/2021 6:11 PM
So, I picked up a spare SM420 from a later truck, 1/2 ton I believe. What are the chances that the speedo gear in this trans is at least closer to the accuracy I need for my 3/4 ton, now that I have the 4.11 gears?
More images
Goach2 #1399127 02/27/2021 4:23 PM
Crusing in the Passing Lane
Luck.
I just remember my Speedo is 11% slow, plenty to keep one’s brain occupied on a trip.
Ed
Goach2 #1399132 02/27/2021 5:32 PM
4.11 ratio axles in 3/4 tons were almost always used behind automatic transmissions. The odds of finding a 4 speed with the right speedometer drive are pretty slim.
Goach2 #1399215 02/28/2021 1:09 AM
The right speedometer gear would be nice, but I'm only wondering if there's a chance that this one would be better than what I got?
More images
Goach2 #1399233 02/28/2021 2:27 AM
Goach2, You can get a Speedometer Cable Ratio Adaptor from Summit or Jegs. Figure out how far off you are and insert the in-line adaptor to your transmission and the problem is solved, no need to search for hard to find gears.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
