9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#1384952 11/17/2020 3:02 PM
PA OUTLAW
PA OUTLAW
Hello all !! Working on 1954 3100 chevy working on the wood bed flooring I chose oak . Anyone have finish Idea's would like to shine uv protection a must !!! wont be hauling anything but a cooler but want to do it right !!! THANK YOU IN ADVANCE!!!!!
jrhackett #1384964 11/17/2020 4:47 PM
I have a 49 and 51--did two beds--Used Watco exterior--looks great on Oak--both are garaged--Bill
jrhackett #1385141 11/19/2020 3:03 AM
Fox Offline
I used a walnut stain and then used Petite Captains z-spar marine clear varnish on yellow pine. My truck stays in the garage and doesn’t have a lot of miles yet (1300), but I have driven it in the rain and snow. It supposedly has built in UV filter/absorbers. It’s for wooden boats and associated pieces so it likely is pretty durable, not bulletproof, but would last quite a long time. I’m hoping that anyway!
https://photos.app.goo.gl/FpWSVWmECv9PYQFUA
https://pettitpaint.com/products/varnish-wood-finishes/exterior-varnish/
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
jrhackett #1385178 11/19/2020 4:04 PM
I used a penetrating epoxy to seal the wood. It’s like water...soaks into the wood.... It does a good job of encapsulating the fibers. It’s flexible so it won’t crack. Unfortunately it needs to be covered over because of a UV problem. I used a flat black enamel. Worked out great... actually, too nice....
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
