| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | Hello all !! Working on 1954 3100 chevy working on the wood bed flooring I chose oak . Anyone have finish Idea's would like to shine uv protection a must !!! wont be hauling anything but a cooler but want to do it right !!! THANK YOU IN ADVANCE!!!!! | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I have a 49 and 51--did two beds--Used Watco exterior--looks great on Oak--both are garaged--Bill | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I used a walnut stain and then used Petite Captains z-spar marine clear varnish on yellow pine. My truck stays in the garage and doesn’t have a lot of miles yet (1300), but I have driven it in the rain and snow. It supposedly has built in UV filter/absorbers. It’s for wooden boats and associated pieces so it likely is pretty durable, not bulletproof, but would last quite a long time. I’m hoping that anyway! https://photos.app.goo.gl/FpWSVWmECv9PYQFUAhttps://pettitpaint.com/products/varnish-wood-finishes/exterior-varnish/
| | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | I used a penetrating epoxy to seal the wood. It’s like water...soaks into the wood.... It does a good job of encapsulating the fibers. It’s flexible so it won’t crack. Unfortunately it needs to be covered over because of a UV problem. I used a flat black enamel. Worked out great... actually, too nice....
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
