3 members (UtahYork, Millenimech, klhansen), 168 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
I want to cover some of the larger firewall holes in my 1953 GMC. What gauge sheet metal should I use? I plan on using screws or small bolts and nuts to attach it.
The original metal was 19 gauge, which can be hard to find. I've used 18 gauge for patches, which is just a touch thicker.
If you want a cleaner look, you should butt weld the patches in the holes.
I welded the holes in the firewall of my 36. I used whatever I had laying around for the larger holes, and the small holes I just welded in, well over 70 of them.
Another quality post.
Real Trucks Rattle
Sir Searchalot
Sir Searchalot
Does not matter what gauge you use. You can use steel or aluminum.
1/4" inch plate might look a little funky. wink
But if bolted in place, any thickness could be used. If welded in, only use steel.
Sir Searchalot
Sir Searchalot
If metal is inside of firewall, you won't see the thickness. Welding a fitted patch would be the best option but bolting will cover the holes. That's the goal. Keep the fumes out.
