2 members (Peggy M, Hotrod Lincoln), 89 guests, and 2 robots.
Topics128,169
Posts1,057,043
Members48,458
1 Offline
Good Morning to you all
Looking for some tricks to getting the slotted head bolts removed to get the motor plate off (pics below for reference). I have tried some heat, tapping the end of a big screwdriver while turning, and an impact driver (not a gun, but the tool you hit with a hammer) which only twisted the bit. I am going to get a bigger hardened bit for the driver and try that, but hoping one of you may have a trick that works.
Thanks in advance
Jeremy
1955 3600 father and son project
H Online: Content
Get the screw head red hot with an acetylene torch. It will back out with nothing more than a big screwdriver. Be sure the screwdriver bit fits the entire slot, thickness and width, even if you have to grind it to fit.
Plan B ............Hand impact with a better quality bit............try harder, technique is everything.
1 Offline
Thanks guys
I will let you know what worked, I was being a little conservative with the heat but will take your suggestion Jerry.
Showkey, yes better bit is going to be the key! I completely twisted the crappy one I have, glad the bit twisted over the screw head, those do not look like very common bolts.
Moderator
Moderator
2 Online: Content
To me it looks like they center punched the ends of each slot to keep the screws from backing out.
Do as Jerry says, a good hammer type impact driver with a good fitting bit and a acetylene torch with a small tip to heat the screw fast in the center of the head and the driver should get them loose.
Don’t use propane, it will not heat the screw fast enough to do much good.
Hope this helps
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Fox Offline
As an addition, get a square shafted screwdriver and put a wrench on it to help you turn it if the bolt is really stuck after heating.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The screws are staked in place so they can be a bit of a bear to get out sometimes. I don't have an oxy/acetylene torch so I do the above. I generally use a really really long screwdriver, 2 foot plus, that has a hex shaft. I attach a 12 inch adjustable wrench and have my son push and twist on the screw driver while I apply additional leverage with the adjustable wrench. Tighten just a bit to get the screw to move a bit, then loosen.
Mike
Moderator, Electrical Bay
If you have a Dremel tool and one of the small grinding bits they make, you can remove the stake bit and then those screws come out much easier.
~ Jon
H Online: Content
Using a carbide or diamond tipped burr in a Dremel tool or a die grinder to nibble away at the stake marks helps, also. Having a torch, machine tools, and 60-something years' experience is hard to beat, though!
1 Offline
Thanks For the help, I found a better bit for my impact driver, help it straight with some tension, and had my son on the hammer. We got all 3 out, and he only hit my hand twice! When I go to reinstall the plate, should i re-peen the screws, or is red loctite acceptable?
H Online: Content
Even blue LocTite should be sufficient. Just make sure the threads on the screw and the block are clean, with no oil on them.
LOL
More training on the hammer. Or revoke his hammer license. Or even better have him holding while you hammer. grin
Like Jerry said, clean threads and just about any threadlocker.
1 Offline
Thanks to you both
More training for sure, that kid has a 80 mph slapshot and can hit any spot on the net from the blue line.....but swing a hammer straight, not so much! I tried getting him to hold the driver but the constant flinching while i was about to swing was driving me nuts.
