2 members (mick53, KEVINSKI),
116
Mod | | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Looking to buy a 235 or a 261 engine was wondering if there is one better than the other and how much work would it be to remove a 216 engine from a 1953 Chevy pickup and installing a 235 or 361. Thanks to all!!!!
Marv. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Marv,
They are essentially the same engine, one is just slightly larger, thus more desirable in today’s traffic.
Ed
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Need more specifics to give a better answer. If the buying price was the same and both engines in about the same condition, buy the 261. More cubes more horsepower. 235 and 261 share a lot of common parts but 261 specific parts are more expensive. See the Tech Tips section for Engine Swap (216 to 235/261).
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | high pressure 235 vs (USA) 261 installed in a 1953 truck:
buoymaker gives good advice/response
please correct/amend the following list:
car 235s have hydraulic lifters truck 235s have mechanical lifters all USA 261s have mechanical lifters
you will be Pre-68 Dave's water pump relocator/adapter (and, most likely you original from motor-mount "plate")
depending on the year 235/261 the motor mounts will be different from the original-engine's
you should be able to use your radiator hose set-up on either
you would most likely have to do a little rerouting/bending of fuel lines on either
both will have larger exhaust/intake manifold ports compared to the 216
both will most likely need adapted/new fuel lines?
both can use your old clutch-housing/clutch-assembly/u-joint assembly and rear motor mounts | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Went from a healthy running 235 to a healthy running 261 in my 53 1/2 ton. With the correct carb on the 261, it has a small noticeable power and torque increase at the seat of the pants.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | FWIW ... The Holy Grail here is the 261 with the "3733950" casting code. This block was designed as an engine for the late AD trucks ('54 and '55 1st Series) and they are a form/fit/function replacement -- requires no modification. You will need parts from your 216 to make it work (depending if you want to keep your 6-volt electrical system). Mine was made in 1959 as a crate motor for the '54/'55 trucks. Not sure if the early 235's are the same way. Later 235's and 261s require some mods to work. Upgrading with the early 261 (if you can find one  ) is easy -- your average orangutan with a hammer and an adjustable wrench could do it. Rebuilding it before hand ... um, not so much.  But either way, if you have a choice, go with the 261. Do 26 cubes matter? YES. That's an 11% increase. The difference on my truck (216 to 261) was that I went from a trailer queen (for longer trips, anyway) to a real highway cruiser. If you want to spend time cruising the Interstate or with guys who have done serious power upgrades to their trucks, every cube matters. You don't want to be the guy who the others are waiting for at the tops of hills.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Or if you are far north, source a 53 Canadian 235 it was standard equipment that year and it can take all the 216 accessories including the manifolds, and comes with the correct 6v starter ring gear. The valve cover even looks like the 216, for extra car show confusion  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |  "2. ALL 235's will require drilling for the water pump adapter plate (to mount it in the higher position)"  The early high-pressure truck 235s require no mods to install (as per John's other statement, below).  3. "The early 261's require no mods to install." - 1954/55st | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | I was editing my post while you were writing, tim ..  My bottom line -- go for the/any 261. 216 to 235 is a good upgrade. 216 to a 261 is a *better* one  Settle for a 235 if you can't find a 261.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . My bottom line -- go for the/any 261. 216 to 235 is a good upgrade. 216 to a 261 is a *better* one Settle for a 235 if you can't find a 261.  - Amen | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Where did I read that all 261's were drilled for hydraulic lifters even if they came with solid lifters? Am I wrong? Different cam required?
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | No. Yes. Yes. From Tim's website http://www.1954advance-design.com/Web%20images/1958-60-rocker-oil/1958-rocker-arm-lubrication.html1954 and later 235 car (not truck) engines with Powerglide had hydraulic. Even with cars, there are noise issues with making 235 hydraulics work like expected. Lots of reading and ask questions before going this route. Many old truck owners like the light clacking of solids.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | The only thing better than a 261 would be one with a long stroke crankshaft that approaches 300 cubic inches. I'm working on accumulating parts for building that engine some time in the not too far distant future. Jerry
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | How you gear the 235 makes a big difference in both in-town traffic and highway driving. If you're strictly a 3 on the tree guy, then you'll have fewer options. If you're willing to change your drive train and study overall ratios carefully, the 235 can be just fine in any situation.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | How you gear the 235 makes a big difference in both in-town traffic and highway driving. If you're strictly a 3 on the tree guy, then you'll have fewer options. If you're willing to change your drive train and study overall ratios carefully, the 235 can be just fine in any situation. Great point Jon. I would take a truck with a babbit pounder 216 if it had a T-5 transmission and a 3.73, 4.10, or larger ratio rear end over a stock truck with a stock drive train and stock 235 or a 261. I bet I would surprise many on race day You can gain more performance from modernizing what goes behind the stovebolt engine than anything you try to do to the engine, including increasing the cubic inches. I know, as the late Lucky Ned Pepper once said to Rooster Cogburn,"I call that bold talk for a one-eyed fat man." (for the record, I am not that old, and I can see poorly out of both eyes). In conclusion, all I will add is, "see you on race day."
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Thanks Carl, now I'll be hearing Robert Duvall speaking that line for days.
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | I’m currently building a 261. Parts cost about $950, plus machine shop time/costs.
Chris | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Thanks Carl, now I'll be hearing Robert Duvall speaking that line for days. That would be John Wayne in "True Grit"... Mike B  | | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | That would be John Wayne in "True Grit"... Actually that would be Robert Duvall's character addressing John Wayne's character.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Actually that would be Robert Duvall's character addressing John Wayne's character. Touche! LOL! Back on the OP question...there's no replacement for displacement, if you can afford and find the 261 then that would be the way I'd go. Mike B  | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Cruising the pits at the Bonneville Salt Flats I saw a tow vehicle with "There's no substitute for cubic money," in nice script painted on the side.
You could keep the 216 and just turn it faster. With some period speed equipment you can up the power a bit and look cool at the same time. Maybe Hot Rod Lincoln could fix you up with a crank drilled for pressure to the rod bearings. Switch to an open drive line rear axle and a three speed overdirve transmission. I think they were available for Chevrolet cars from '55 on. I had a daily-driver '50 Stude for 10 years with 4.56 gears and an overdrive. It effectively had 5 usable speeds and got consistently 28 MPG on the road. It would make a comfortable 60MPH. A 4.11 run through a 30% overdrive would give you a 2.88 final drive ratio. That, with a five-speed trans should do nicely in an AD pickup. A 216 will have way more torque than a flathead 170 Studebaker and the later 3-speed trans was a big improvement. Might be cheaper than finding and rebuilding a 261 and you'd surely get better gas mileage than a 261 run through a straight 3-speed and a 4.11 rear. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | With the modification I'm currently working on, a 235 crankshaft and pistons is going to fit into a stock-appearing 216 block, using modified 292 connecting rods and a camshaft slightly hotter than a Corvette/261 item. It's also going to have a high volume oil pump and a leakproof rear main bearing seal. With a little tinkering on the cylinder head for better gas flow, it will keep up with, or possibly out-torque a stock 235, in a package that looks like the original 216. Given the outrageos prices people are charging to do a stock rebuild on a Babbit pounder these days, the cost won't be much different, as well! Jerry
| | | | | Joined: Oct 2015 Posts: 1 Moderated | | Moderated Joined: Oct 2015 Posts: 1 | Hotrod Lincoln, did you get your setup finished? Your upgraded 216 | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | This thread is a little over two years old. I've actually moved on from the idea of using a stock stroke 235 crankshaft in a 216 block, although that approach would still be possible. By doing some machining on the main bearing webs of the 216 block to narrow the thrust bearing area, later model 235 main bearings and a full pressure 235 crankshaft can be used, and the crankshaft stroke can be increased to 4 5/16"- - - -a stroke gain of 3/8". Combined with aluminum pistons for a Buick engine and Nissan 4 cylinder connecting rods, the displacement will increase to 258 cubic inches and there will be a big increase in compression ratio. All these modifications will be incorporated into an engine that looks exactly like a 216 from the outside. Similar bore and stroke changes to a 235 will yield 270 cubic inches, and boring and stroking a 261 will make it a 300. I'm in the process of finalizing the rotating assembly for a 258 cubic inch "216" that will include several other, very radical internal modifications. Some health concerns with a couple of close family members have slowed me down somewhat, but I'm making steady progress. Jerry
| | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | Since the direction of this thread changed, there is no sense in continuing. I’m locking this thread.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
