8 members (Gdads51, Otto Skorzeny, warlock, RoadsScholar, Ponchogl, 55shaker, k2handyman, 5 Window 9434),
104
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Hi, What would have been the original rim size for my 51 1ton? Thank you | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 51 3804, the standard tires were 7.00" by 17" 6 ply rated mounted on 17" by 5" wide wheels with a 7/16" offset. Optional tires were 7.50" by 17" 8 ply rated mounted on the same wheels, hope that helps. | | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Thank you 3b, That was very helpful. My truck came with 16.6's in the front and one 17.5 and one 18 on the rear. Thanks again, Gerry | | |
