0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
I have a 1965 C10 with a 1975 250 in it. It currently has a Rochester Monojet that has been jerry-rigged for a manual choke setup (auto choke mechanism disabled).
What would be a good choice for a manual choke carb. for a 1975 250 ? (if there is one)
1965 Chevy C10 Longbed Fleetside
H Online: Content
Why not just fix the automatic choke? Manual chokes belong on vehicles with acetyline headlights, standard transmissions, hand cranks instead of electric starters, and clincher rim tires. They're all about the same level of obsolete. A properly adjusted automatic choke is smarter than all drivers, and most mechanics.
If it has the intergraded head you may be out of luck, otherwise the carburetor shop .com has a list of the carburetors GM used from the factory.
ESum
