1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
I'm looking at a 235 that appears to be from a '54. There's a series of numbers just in front of the no. 3 plug. Can anyone tell me what these numbers are?
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/24434/filename/Paramount 235 1.jpg[/img]
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
Thank you, I have that but it doesn't show these numbers
Tearing her down
More images
Those casting numbers on the block are the last three digits from all of the different heads that fit that block.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Mike, I have never heard or read that before. Where did you get that information? I'd like to know more. The picture JoeR posted is of a head, and I have never understood what those markings mean.
Thanks.
Professional Novice
Joe, those numbers from the passenger side of the head don't reliably decode the head casting, let alone the engine. What Tim was trying to politely point you to is the casting numbers that will ID head and engine block original usage. The head casting number is on the driver's side of the head, just above the second exhaust port. What's the 7-digit number there?
To ID the block, either the engine serial number that is stamped on the machined pad just aft of the distributor, and sort-of behind the dipstick (if it's still there), or the casting number, low and in front of the distributor, will ID the block (casting number can be hard to see if the engine is still in a vehicle, view blocked by the fuel pump and/or motor mount). Can you see either of those numbers on the engine block?
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
