3 members (kbenz, JW51, 1 invisible),
218
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am about to hook up my fuel line from the fuel pump to the carb and need to know, should I be using steel line or steel braided flex or does it make a rip. If it doesn't matter I just as soon use the flex and be done with it. However I don't want to start another Chicago fire in my garage or anyplace else. Oh yeah, 350 chevy small block HO with Holly carb.
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You could go either way, but running it with hard line would look much cleaner and there would be no chance of it getting cut as it would b rigid and not flop around anywhere.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Hard line for sure. Just use a coat hanger to make a template so to speak. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion....I like to use the pre-made brake lines found at all the parts houses to make my solid fuel lines. Cut off one end flare and you've already got a fitting for the fuel pump. The stuff bends like butter and as was pointed out before, will be a lot cleaner looking and ultimately safer. A little chunk of rubber line at the carb end, will dampen and isolate any vibrations.
Dave | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks guys, all good suggestions.
~Jim
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Having a tube bender is useful and a good idea since you won't kink the tube and either restrict the flow or create a weak spot for a future leak. If you can't borrow one and there is a Harbor Freight in your town you can pick one up for $7.00 and they are pretty handy. (HF does mail order too) Here's a picture. [img] http://www.harborfreight.com/cpi/photos//03700-03799/03755-t.gif[/img]
| | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Steel lines as much as possible...
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | seriously hand bending fuel line is very easy. really run a hard line in 3/8, (5/16 min)
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's not really necessary to remove the flare from the end where the rubber hose goes on. Most guys i know will leave the flare to act as a barb to help retain the hose to the line. Or in my case, the 1 hose in my fuel system has threaded fittings on it, so it just goes on like a regular brake hose.
