2 members (Steelonsteel, Hotrod Lincoln), 136 guests, and 4 robots.
Topics128,109
Posts1,056,261
Members48,439
#138400 06/14/2007 10:00 PM
I am about to hook up my fuel line from the fuel pump to the carb and need to know, should I be using steel line or steel braided flex or does it make a rip. If it doesn't matter I just as soon use the flex and be done with it. However I don't want to start another Chicago fire in my garage or anyplace else.
Oh yeah, 350 chevy small block HO with Holly carb.
~Jim
#138401 06/14/2007 10:38 PM
You could go either way, but running it with hard line would look much cleaner and there would be no chance of it getting cut as it would b rigid and not flop around anywhere.
Bill Burmeister
#138402 06/15/2007 1:36 PM
Hard line for sure. Just use a coat hanger to make a template so to speak.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#138403 06/15/2007 2:08 PM
Just a suggestion....I like to use the pre-made brake lines found at all the parts houses to make my solid fuel lines. Cut off one end flare and you've already got a fitting for the fuel pump. The stuff bends like butter and as was pointed out before, will be a lot cleaner looking and ultimately safer. A little chunk of rubber line at the carb end, will dampen and isolate any vibrations.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#138404 06/15/2007 10:53 PM
Thanks guys, all good suggestions.
~Jim
#138405 06/17/2007 4:13 PM
Having a tube bender is useful and a good idea since you won't kink the tube and either restrict the flow or create a weak spot for a future leak.
If you can't borrow one and there is a Harbor Freight in your town you can pick one up for $7.00 and they are pretty handy. (HF does mail order too)
Here's a picture.
[img]http://www.harborfreight.com/cpi/photos//03700-03799/03755-t.gif[/img]
#138406 06/17/2007 4:34 PM
Steel lines as much as possible...
Another quality post.
Real Trucks Rattle
#138407 06/17/2007 5:36 PM
seriously
hand bending fuel line is very easy. really
run a hard line in 3/8, (5/16 min)
Jim & Caroline
#138408 06/17/2007 11:30 PM
It's not really necessary to remove the flare from the end where the rubber hose goes on. Most guys i know will leave the flare to act as a barb to help retain the hose to the line.
Or in my case, the 1 hose in my fuel system has threaded fittings on it, so it just goes on like a regular brake hose.
Bill Burmeister
