| | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I have a 1965 C10 with a 1975 250 in it. It currently has a Rochester Monojet that has been jerry-rigged for a manual choke setup (auto choke mechanism disabled).
What would be a good choice for a manual choke carb. for a 1975 250 ? (if there is one)
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Why not just fix the automatic choke? Manual chokes belong on vehicles with acetyline headlights, standard transmissions, hand cranks instead of electric starters, and clincher rim tires. They're all about the same level of obsolete. A properly adjusted automatic choke is smarter than all drivers, and most mechanics. Jerry
| | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | If it has the intergraded head you may be out of luck, otherwise the carburetor shop .com has a list of the carburetors GM used from the factory.
ESum
