| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 123 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 123 | My 1947 Chevy 3100 has a 1959 235 engine and I want to replace the fuel pump it has now for one with the glass bowl on top to be more vintage. I do not want one with the vacuum feature. In fact, I had one ordered from a supplier and waited a while for delivery...then I called back and they said they had to locate another company to provide these. Some on eBay but I had rather have a new one. One like I want without vacuum should run around $75 new. Who can help me? Thanks, ray | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Most of the "new" sediment bowl fuel pumps I've seen are NOS parts. I'm not aware of anyone repoping them. There could be and I'm just not aware of them. You can buy rebuild kits for yours that will make it as good as new. It's not difficult to rebuild one. Just replace the gaskets and one way valves. Just make sure you're putting the one way valves in the right way.
| | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | Just saw one on eBay "1937 TO 1951 CHEVROLET SINGLE ACTION REBUILT FUEL PUMP FOR TODAY'S FUELS AC 429", but they want $250 for them. Same seller has the one with vacuum pump for $10 more.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Chevs of the 40s Classic Parts Jim Carter Truck Parts Antique Chevrolet Truck Parts | | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | Seems all the usual suspects, JC, Chev's of the 40's, Classic Parts, The Filling Station, are backordered on these.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Usually the check valves are okay after cleaning The main diaphragm material can be ordered from McMaster Carr You will need to cut it round and stamp holes yourself But that’s part of the fun -s | | | | | Joined: Aug 2016 Posts: 123 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 123 | You have hit the nail on the head! | | |
