6 members (JW51, Jon G, MRMEROTH11, Peggy M, Southerntruck, 1 invisible), 113 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#1382794 10/30/2020 10:50 AM
Hi everyone. I have a 37 maple leaf (Canadian truck) very little information is available that I can find. I’m looking at making it a little more drivable on Modern roads moderns rims/ brakes gearing etc. the truck is a bit too far gone and allready hacked up from pervious owners. The one big problem I have is the bolt pattern. It is a very large 5 bolt that appears to be unique to maple leafs. Has anyone ever taken the dual my spacer of the front wheels to fit a modern steel wheel on the drum and then convert rear to single wheel. Any help would be appreciated thanks
Mike t #1382892 10/30/2020 11:22 PM
3B Offline
Hy Mike t, welcome, your truck could be a 2 1/2 ton or a 3 ton, could you post the serial number? Your truck should be equipped with Motor wheels which are hub piloted wheels. I doubt that here is a single wheel front hub from the lighter trucks that would fit on your trucks spindle.
Mike t #1382903 10/31/2020 1:01 AM
Thanks for the reply not sure how to post a picture here serial is 7152401258 and it’s a model 16-48 if that helps. Ideally I’d like to upgrade the wheels brakes and gearing rear end is easy but match the front wheels is difficult with this bolt pattern. Disc brake conversion would Be ideal that seems to be the hot topic. Basically would like to get it rolling safely down the road and. The brakes and wheels on it all need attention so I’d rather replace with easier to get more modern stuff but would settle for anything really
Mike t #1382907 10/31/2020 1:42 AM
3B Offline
Hy Mike t, what you are describing sounds like a chassis swap to me? Find a chassis with as close to the same wheelbase as your truck and swap your body onto it.
Mike t #1382911 10/31/2020 2:10 AM
Crusing in the Passing Lane
Are the 5 front lugs on a 7.25" pattern? And does the rear have 10 bolts? That is a common bolt pattern in the 'States. None-the-less, a modern running gear or chassis would be handy.
Ed
3B #1382929 10/31/2020 11:39 AM
Yeah I’m toying with that idea as well wheel base isn’t an issue it’s a cab and chasis width of the donner becomes tricky it seems everything but an s10 is too wide and than a low riding cab and chassis may look funny. Where u able to tell the tonnage by my vin thanks
Mike t #1382930 10/31/2020 11:43 AM
No unfortunately the mAple leaf is different i had a set of what your describing line up from a motor home p30 chassis I believe but the ddonr fit. The maple leaf is 5 in the front and 5 in the back 6 in center and 8 inch stud spacing
Mike t #1383006 10/31/2020 11:11 PM
3B Offline
Hy Mike t, your Maple Leaf is a 2 1/2 ton version, unfortunately my parts book only goes back to 1938.
3B #1383020 11/01/2020 12:21 AM
Thank you I was guessing it to be a two tonn but didn’t have the info is there anything else you can tell me from the vin thanks
