| | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hey all, So I'm still looking for that stock 3spd OD tranny to convert my current 4 on the floor saginaw in my 1960 C10 I have done some research (a whole winters worth) and decided that this...for me would be the easiest way to get some more top end. the only real mods I can see are shorting the drive shaft and converting the shifting. Which brings me to my question. I've noticed on alot of period OD trannys from the 50's and 60's have the OD solenoid sticking outreally close to the shifters. Would a modern 3spd floor shift kit have room to clear the solenoid? It looks pretty close to me. Has anyone here done this before and if have ran into this problem? I'm still trying to finalize the details before I purchase a 3spd OD
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | These bent shifter arms have worked flawlessly for 30k, that's no BS. This UP-OVER-UP allows the shifter IN THE MIDDLE OF THE FLOOR .
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
