| | | Forums66 Topics128,041 Posts1,055,483 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | When I started up this morning I could feel a funny vibration that I had not noticed before. The rpm was up a little as it was still cold, and I could feel a rythmic vibration that would last about 2 seconds, then go away for about 4 seconds. Not sure if this is related, but since I have had the truck, there is a slight vibration that I can feel in the steering wheel that slowly gets worse until at about 40MPH, what sounds like a piece of sheet metal vibrating starts up and then goes away at about 45 MPH. The vibration in the steering wheel continues to increase, and at this speed, I can now feel it in the dash. The generator was overhauled about 2 years ago; the water pump and harmonic balancer are of unknown age. I watched the front of the engine and reved it up and down some and nothing looks loose, and it all sounds good. Right now it is not bad and does not bother me. I spend most of my time at about 40mph anyway, so it is not too noticeable. But if this is a sign of maybe a component on its way out, it would be nice to get it fixed before it fails. Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Tire tread separations. I know this doesn’t take into account “sheet metal vibrating” but it could account for vibration at different speeds. Good luck.
| | | | | Joined: Feb 2004 Posts: 29,752 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,752 | A tire won't cause vibrations on startup. I'd suggest loosening or removing the fan belt on a cold start to see if the shake is internal or external. A slightly bent fan blade can cause some oddball harmonics at various engine and/or vehicle speeds, and some types of tires can develop flat spots when they sit for extended periods of time- - - -the dreaded "nylon thump" that early synthetic cord tires used to have. I've seen those things have teeth-rattling shakes for 5 miles or more on a cold day! Jerry
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | I’ll try removing the belt next time I run it; that will eliminate the pump, fan, and generator if the vibration is still there. The tires where replaced when I got the truck, so only about 4 years old and not very many miles. Though a bad tire from the factory is still a bad tire. Lee
