4 members (moparguy, Phak1, NJC, Peggy M), 77 guests, and 1 robot.
Topics128,157
Posts1,056,876
Members48,458
Hy group, I want to lower the rear of the 53 3100 1/2 ton pu presently I have put spaces to get an idea what is happening. Let start by saying that I got the truck without the original rear end, I got a 62 1/2" wheel flange to flange 6 bolt posi rear that I will need to grind the mounts off that held the trailering arms for the spring mounting. When I put 3" spacing blocks and set back the rear about 2" I still have way more space between the tires and the wheel openings then I want, I can't go much more or even this much space without the bottom of the ubolt supports hitting the ground in the case of a flat tire. Any suggestions appreciate in what you have done to get the rear lower.Sorry to post so many question but who knows best then you, who have done it all. Thanks Ed ke6bnl
Ed [email protected] ( 1950 f1 & 1963econo 1953 Chevy pu AD 3100, 1948 F1
Agua Dulce Ca. 91390 70 chevy S/B) 1948 **** F3
So. Calif. 70 mil N.Eof Los Angeles
1963 econoline, 50 f1 pu, maybe 53 chevy pu, 50 f3 pu, 70 chevy shortbed c10,
Check out Chevy1's website . Lots of info there, including a list of rear ends that interchange and backing plate-to plate dimensions.
Hope this helps...... smile
*** GMC ***
