9 members (3B, BarryP, Ribside, DadsFirstPickup, Ol' Red, Donf, Biermann, Jon G, UtahYork), 142 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
#1382498 10/28/2020 2:10 AM
Moderated
Moderated
1 Offline
I have a 1953 chev 2 tonne truck which has a Eaton 5.4 to 1 ratio Diff and was wondering if anyone knew of a 4.1 or around that ratio that would fit.
3B Online: Content
3 Online: Content
Hy 1953Gus, welcome, in Canada an 1100 series was a 1 1/2 ton truck, I'm afraid there are very few if any choices for differential gear ratios for an 1100 rear axle.
Big Bolt Forum Moderator
that is a nice looking truck!! Welcome to the site!
Mike
Nice truck. Welcome
Hi from hunter valley cool truck Keeping the dream alive
Nice 53, I need some advice I have a 46 two ton, I can put it on jack stands and count the number of turns per one rotation. I need the info on what I need to look for. I'm parting it out. Doc.
Doc, you won't get a good guesstimate that way, since the axle gears and spider gears might also get involved. With the truck on a flat surface, put a paint or chalk mark on one rear tire, and roll the truck straught ahead one turn of the rear wheels. Count the number of turns of the drivershaft for a pretty accurate idea of the gear ratio. The 5.40:1 ratio in the original post would result in almost 5 1/2 turns of the driveshaft. Putting a paint or chalk mark on the driveshaft or universal joint will help you get an accurate count.
