1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 202 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 202 | My '61 Apache 10 has the original 3-speed with overdrive, and column shift. I've noticed lately that the column shift seems stiff in the Forward <-> Rearward axis. Shifting R <-> 1 and 2 <-> 3 seem 'normal'.
I haven't done any work to the truck that would have affected the shifting. The shop manual and supplement don't seem to cover relevant adjustments or troubleshooting. Is there a preferred method to lubricating the shifting mechanism?
Thanks!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars: 1960 Impala - "Frankie" (Frank Sinatra) 1961 Apache - " 'Mater Jr." (wrecker) 1965 Corvair Monza Convertible 1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years) 1972 SuperBeetle Convertible - "Juliet" 1976 SuperBeetle Convertible - "Olaf" 1988 Alfa Romeo Spider Veloce - "Romeo" | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I have a ‘65 that had the same problem. I sprayed PB Blaster through the area around the shift lever and it loosened right up. Be sure to hold a shop rag underneath your lever area to catch overflow and prevent it from staining your paint or seat cover.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | You might also find a buddy to work the shift lever while you are in the engine bay looking to see how gummed up the shifting rods are at the steering column and at the trans. Is there a chance that a shifting rod is fouling with something? Or that the lube/grease at the shift collars has gummed things up? If this is new behavior, I think it is easy to id and fix. | | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | Sounds like the shift tube needs to disassembled, cleaned and relubed.
ESum
| | | | | Joined: Mar 2019 Posts: 202 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 202 | Based on everyone's suggestions, I shot some Aerokroil on the shifting rods and shift lever on the column. It really freed everything up, and seems to be shifting smoothly. It seems odd to me that this problem seemed to worsen lately...perhaps the arrival of cold weather cause the old grease to harden more.
This spring, I plan on disassembling the column, and clean and lube everything.
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars: 1960 Impala - "Frankie" (Frank Sinatra) 1961 Apache - " 'Mater Jr." (wrecker) 1965 Corvair Monza Convertible 1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years) 1972 SuperBeetle Convertible - "Juliet" 1976 SuperBeetle Convertible - "Olaf" 1988 Alfa Romeo Spider Veloce - "Romeo" | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Good thing you got it lubed up and sliding. When I had my 70’C10 when I was 16, I broke the pivot ball on my column and was up the creek for a while. Young, broke, no knowledge of how to fix. | | | | | Joined: Mar 2019 Posts: 202 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 202 | Good thing you got it lubed up and sliding. When I had my 70’C10 when I was 16, I broke the pivot ball on my column and was up the creek for a while. Young, broke, no knowledge of how to fix. That was my concern too...that I'd end up breaking or bending something that's hard-to-find! I'm surprised that the shop manual doesn't cover this subject in any detail. -Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars: 1960 Impala - "Frankie" (Frank Sinatra) 1961 Apache - " 'Mater Jr." (wrecker) 1965 Corvair Monza Convertible 1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years) 1972 SuperBeetle Convertible - "Juliet" 1976 SuperBeetle Convertible - "Olaf" 1988 Alfa Romeo Spider Veloce - "Romeo" | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I'm surprised that the shop manual doesn't cover this subject in any detail.
-Kevin Who needs a shop manual? If it doesn't move, oil the heck out of it. If it does move, weld it back in place. (Redneck shop manual reference.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I’ve not had an opportunity to look over any 60-62 steering columns with a column shifter. If they are similar to the 63-66 columns, then my DIY might help with trouble shooting a problem. My DIY has 4 sections. DIY Steering Column Stuff | | | | | Joined: Mar 2019 Posts: 202 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 202 | I’ve not had an opportunity to look over any 60-62 steering columns with a column shifter. If they are similar to the 63-66 columns, then my DIY might help with trouble shooting a problem. My DIY has 4 sections. DIY Steering Column StuffThat is a great resource! I'll follow it this spring when I refresh my steering column. I'll note any differences in my '61 column for the group. Thanks for the link! -Kevin
