| | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 1 Moderated | | Moderated Joined: Oct 2007 Posts: 1 | Will a 1954 235 fit in a 1958 Chevy. I hear the mounts location are not the same so don’t want to buy the 54 block until I’m sure. Any info will be appreciated!
chevyator
| | | | | Joined: Sep 2020 Posts: 40 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 40 | I just finished putting a 1958 car 235 in a 1952 truck. I had to install two holes in the front engine plate with a new 1952 front engine cushion and I used the 1952 bellhousing and two new 1952 rear mounts.
So, as long as you're using front and rear mounts, then yes it will work. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy chevyator, welcome, unfortunately if the engine block is truly no newer than 1954 I don't think it will have the front/side bosses that the 1955 B or second series through 1959 use to bolt the front engine mounts to. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | I've got a 55.1 261, has no cast pad or bolt holes on front sides of block, can only mount from timing cover plate.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
