5 members (Charles in CA, Steelonsteel, Shaffer's1950, 52GMC35424JD, Hotrod Lincoln), 91 guests, and 3 robots.
Topics128,049
Posts1,055,665
#1382490 10/28/2020 1:07 AM
Moderated
Moderated
Will a 1954 235 fit in a 1958 Chevy.
I hear the mounts location are not the same so don’t want to buy the 54 block until I’m sure. Any info will be appreciated!
chevyator
chevyator #1382503 10/28/2020 2:50 AM
I just finished putting a 1958 car 235 in a 1952 truck. I had to install two holes in the front engine plate with a new 1952 front engine cushion and I used the 1952 bellhousing and two new 1952 rear mounts.
So, as long as you're using front and rear mounts, then yes it will work.
chevyator #1382513 10/28/2020 4:11 AM
3B Offline
Hy chevyator, welcome, unfortunately if the engine block is truly no newer than 1954 I don't think it will have the front/side bosses that the 1955 B or second series through 1959 use to bolt the front engine mounts to.
chevyator #1382563 10/28/2020 5:16 PM
I've got a 55.1 261, has no cast pad or bolt holes on front sides of block, can only mount from timing cover plate.
BC
1960 C60 pasture art
