Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1382474 10/27/2020 11:07 PM
My '61 Apache 10 has the original 3-speed with overdrive, and column shift. I've noticed lately that the column shift seems stiff in the Forward <-> Rearward axis. Shifting R <-> 1 and 2 <-> 3 seem 'normal'.
I haven't done any work to the truck that would have affected the shifting. The shop manual and supplement don't seem to cover relevant adjustments or troubleshooting. Is there a preferred method to lubricating the shifting mechanism?
Thanks!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1965 Corvair Monza Convertible
1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
I have a ‘65 that had the same problem. I sprayed PB Blaster through the area around the shift lever and it loosened right up. Be sure to hold a shop rag underneath your lever area to catch overflow and prevent it from staining your paint or seat cover.
You might also find a buddy to work the shift lever while you are in the engine bay looking to see how gummed up the shifting rods are at the steering column and at the trans. Is there a chance that a shifting rod is fouling with something? Or that the lube/grease at the shift collars has gummed things up?
If this is new behavior, I think it is easy to id and fix.
~ HB
1962 Chevrolet C10
1962 Suburban
Sounds like the shift tube needs to disassembled, cleaned and relubed.
ESum
Based on everyone's suggestions, I shot some Aerokroil on the shifting rods and shift lever on the column. It really freed everything up, and seems to be shifting smoothly. It seems odd to me that this problem seemed to worsen lately...perhaps the arrival of cold weather cause the old grease to harden more.
This spring, I plan on disassembling the column, and clean and lube everything.
-Kevin
Fox Offline
Good thing you got it lubed up and sliding. When I had my 70’C10 when I was 16, I broke the pivot ball on my column and was up the creek for a while. Young, broke, no knowledge of how to fix.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1382657 10/29/2020 9:57 AM
That was my concern too...that I'd end up breaking or bending something that's hard-to-find! I'm surprised that the shop manual doesn't cover this subject in any detail.
-Kevin
-Kevin
Who needs a shop manual?
If it doesn't move, oil the heck out of it.
If it does move, weld it back in place.
(Redneck shop manual reference.)
I’ve not had an opportunity to look over any 60-62 steering columns with a column shifter. If they are similar to the 63-66 columns, then my DIY might help with trouble shooting a problem.
My DIY has 4 sections.
DIY Steering Column Stuff
That is a great resource! I'll follow it this spring when I refresh my steering column. I'll note any differences in my '61 column for the group. Thanks for the link!
-Kevin
