| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I have a lt1 that I'm putting in my '50 3100. The engine hasn't been started for a couple of years and most likely will be another before it's ready to go,(stored in a dry environment). The engine does rotate. What, if any, lube should I put into the cylinders to keep them from seizing up? I assume rotate it afterwards? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Automatic trans fluid works good. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | They make a "fogging oil" that is is a spray can that you can spray in spark plug holes that coats entire cylinder bore that I like. As with all spray products, hold on to the tube to make sure you don't shoot it into the cylinder bore. https://www.amazon.com/STA-BIL-22001-Fogging-Oil-av/dp/B000H7CKAY | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Drain most of the oil out of the pan, and then turn the engine upside down. A friend who ran a salvage yard stored all his take-out engines that way, and other than doing a lot of smoking on startup, he never had a problem with selling engines that spent a lot of time in storage. The residual oil will creep past the piston rings and flood the combustion chambers. Bolt sheet metal or plywood over the intake and exhaust ports or manifolds to prevent humid air from cycling in and out of cylinders with the valves open due to changes in temperature. Those cylinders will rust, unless the airflow is plugged off some way. Jerry
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I've always used WD40 as a cylinder fogger. Probably not a good as a real fogger, but it's always convenient and available, and I've never had a problem with stored motors.
BTW, NEVER wrap an engine in plastic sheeting, visqueen, etc. Air contains moisture; plastic sheet traps it inside the engine. I've known two people who ruined engines that way. One was a Hot Rod magazine project where the builder wrapped his brand-new 351 Cleveland motor in plastic while he finished '29 Roadster; when he installed the engine and tried to start it, it was completely frozen, the cylinders were rusted beyond saving, and he had to get another new engine.
1951 Chevy Panel Truck
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Another option is to loosen up the rocker arm adjustments so all the valves stay closed, after oiling the cylinders through the spark plug holes and replacing the plugs. I bought an Oldsmobile V8 with very low mileage from a salvage yard, only to find that one cylinder had rusted badly enough to require a sleeve. The valves on that cylinder had been open, allowing air in, for about 6 months. Even the rusty cylinder showed virtually no wear, but the rings were rusted solid and the cylinder was badly pitted. Jerry
