0 members (),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | I am toying with the idea of making a new frame for my 62 burb I figure by the time I have finished cuting and welding the old frame to get what I want I may as well just start from scratch. Has any one done this and can someone help and send me in the right direction? I want to use early 80s front suspension with disc brakes, my power train is 94 buick roadmaster lt1/4l60 trans and rear end, cnotch and bags all the way around, 4link for the rear
it's not how much time you spend on it, it's how you spend your time with it
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are you a good welder and fabricator? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The same basic IFS was used '63 to '87 and starting in '73 they are all leaf sprung in the rear.
I wonder if you couldn't make a wheelbase adjustment installing the four-link and more easily adapt the entire later frame than scratch build one for so similar a vehicle.
I guess I don't see a compelling reason to scratch build in your description. Is there something more to your plans that you aren't telling us?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have some experience in chassis building. First thing I would do is go to your local book store or amazon.com and pickup a book or two on the subject. Then decide if you have the tools/equipment/ability to see the project through. You don't necessarily need a frame jig. I have built one on a heavy duty oak bench before I built my own jig out of 4x4 heavy wall tubing. Some photos here. Good luck should you decide to continue. | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | I have exelent fab skills the work doesn't scare me. If I am going to go through work to switch every thing around ie new front end and four link in the rear I am thinking I may as well make new frame rails at the same time and end up with a nice clean boxed frame.
| | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | thanks for the pics ghostrider you have made my decision easy I am going to custom fab a frame. There is nothing nicer than a clean frame even though most wont see it to know its under there is reward enough.
| | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Ghostrider is correct, there's a few excellent books on building chassis and frames. Without trying to adverise I got a great book from Amazon called How to build Hot Rod Chassis and is an excellent book on frame building from the ground up. Regretfully though most of the frame parts are prefabricated so to find parts for the burb might be difficult and you might have to start from scratch.Big thing in welding frames is safety and good welds. Bob T | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | This is also a decent book I've browsed through:
Chassis Engineering: Chassis Design, Building and Tuning for High Performance Handling by Herb Adams | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | thanks for all the info looks like I am going shopping to the book store this weekend Thanks again and keep the tips and pics comming Burbnburp
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Gostrider, that's some good looking welding you've done.
~Jim
