3 members (FAST55, GRNHydra, Wally / Montana), 93 guests, and 6 robots.
Topics128,077
Posts1,056,014
Members48,433
Page 1 of 2 1 2
I found you guys when searching for a downloadable copy of an assy manual for my truck. Thank you so much for having it on your site!!
I look forward to reading in this section of your site!!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Moderator
Moderator
2 Offline
Welcome to the garage Panel Man!!
In this garage there are no stupid questions.
So ask away.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
AD Addict & Tinkerer
Welcome to the “Bolt”. The expertise you will find on this site is astounding and all you have to do is ask!
Phil
Project Journals
Stovebolt Gallery Forum
Welcome to the 'bolt. Please introduce yourself in the welcome forum as well.
Another quality post.
Real Trucks Rattle
Jack of all trades and a Master of None!
Welcome!
My57Suburban
This is the slickest swap I have seen for trucks
EZChassisSwap.com
I could swear I posted pics here already, but here are some. This is around when I first got it:
Removal of water-filled engine in 2017:
Huuuuuuge progress today!!!!
1. The engine has been running, but I didn't have time to throw the timing light on it until today. I had blindly turned the distributor when I got it running at the beginning of the month, bc it sounded a little off, but really needed to check it with a light.
Today I threw the light on it, and thankfully, it was only at 8 deg BTDC (I thought it was much worse). I adjusted the timing to 4 deg BTDC and she sounds great now. I let it run for about 15 minutes, and it didnt get any hotter than 210.
2. Since I put the new valve covers and gaskets on, I'm not seeing anymore oil leakage from the heads.
3. I had a very minor oil drip by the timing cover when I first ran the engine, which really bothered me bc the pan gasket is a brand new blue rubber 1 piece. I tightened the 2 bolts at the front of the pan, and no more leak. Whew!!
4. I test fit my driver's seat and started prepping it for install. It's a power seat, and I need it moved back on the tracks in order to get it set up. After reading about it online, I learned how to hook it to a battery and move it. So far I only have the tilt option working, but I'm just so happy to see it working!
5. My Lokar gas pedal arrived today, so once I get the seat adjusted, I can test fit the pedal and install it.
Great day!!!
Here is the test fit of my driver's seat yesterday, and its power connector:
Got the back and forth motion working again. Thank God for the internet and WD-40!!
Also found my windshield wiper linkage that's been MIA in the garage grin
New gas tank on the way, should be here Friday!
3-row aluminum rad from Summit went in today grin
Perfect.
I test fitted the new gas tank on Saturday, it's going ok but is going to take me some time to do, as it's my first. I am also waiting for the sending unit and pickup tube to arrive. I'm hoping I can get this thing installed within the next month, before the REALLY crappy weather kicks in. I'd love to see if the tranny's good, and if it will move on its own, before year-end.
I needed to add a few items on my recent Summit order for free shipping, so I added on some Cherry bomb mufflers. grin
It will require some tweaking, but I got the gas tank installed yesterday:
Hope everyone's doing well- my project is sitting out in the crappy weather, waiting for Spring to arrive. Someone please shoot that groundhog.
All is cold in Colderado. Except my shop heater that keeps my shop so hot I have to leave the door open.
Do you have any "armor" around your gas tank? Jeep put receiver hitches on the mid/late 90's Grand Cherokee's to protect the gas tanks.
Real Trucks Rattle
No, nothing yet. I have in-fact considered a hitch for that truck, though.
Ordered my first tire for this truck today. My all time favorite, BF Goodrich Radial T/A!
I ordered a 205 60 R15, hoping it will drop the front at least an inch, as the current skins are 235 70 R15. They were on the truck when I got it and I hate them, lol.
EDIT: per the web, the new tire will be 3" smaller in total diameter, so it looks like I'll get 1-1.5" drop. Woot!
New tire is on- I also have a new chrome center hub on the way.
Looking good!
Originally Posted by MNSmith
Looking good!
Thanks! I'm hoping I didn't go *too* small. I wanted the front end to drop down a little closer to the ground, which is why I went with the "60" in 205 60 R15. But, now I have a bigger gap between the body and the tire. It is what it is I guess. The original tire on that side had a slow leak, so it needed to be replaced anyway!
The first center cap arrived in the mail today. It's gotta make this look better than its current state!
https://www.stovebolt.com/ubbthread...umber/28433/filename/20210224_174822.jpg
Got my center cap on tonight, looks much better (attached).
I also learned tonight that my truck would have had clear parking light lenses! I have to check a box in the garage, to see if the seller included those (4 years ago, lol).
Ordered a used inner fender today. I don't have either one, and I think it was a good deal (still has the OEM wire clips on the inside), so we'll see how it goes.
I always have a tough time when it comes to buying parts. I have no self control with car parts, so I really have to tell myself OK THAT'S IT FOR NOW!!! smile
I only get in trouble once a month for buying car and truck parts... when the credit card bill comes in! I used the Classic Parts web site for my missing inner fender (67 Suburban).
Real Trucks Rattle
I like buying OEM parts, when possible, because:
1. the quality is better
2. the metal used at the time is better
3. the price is usually cheaper (as they usually need to be sanded and repainted)
I will buy repro parts when I have to, but I like using original stuff for a driver, when possible.
Passenger side inner fender arrived today! I'll be looking it over tonight.
Installed a new Lokar dipstick and filler tube today in my PG! The other tube I had did not look to be correct.
Got my Lokar gas pedal temporarily installed today. I'll get a pic once I have it finalized.
I'm really surprised the OEM gas pedal is missing from this truck, but I guess I shouldn't be.
The gas tank is officially in! I started running the new fuel line, we'll see if it leaks.
I also finished the install of the gas pedal and hooked up the throttle cable.
Finally got a steering wheel nut. Only took 4 years 😁
I put gas in the new fuel tank last night, and started bolting up the Cherry Bombs smile The new 5/16" steel fuel line has been run all of the way up to the engine (that's quite a bit of fuel line on this truck!).
With any hope I'll be firing it up either tonight or tomorrow (Sat).
Ran the truck today, the cherry bombs sound like mechanical music, and I was so proud to see the new custom tank feed the engine on its own!!
Next steps: test brakes and tranny.
Your progressing very nicely!
When you get to your brakes, I strongly suggest buying rebuild kits for the master and the wheel cylinders and rebuild them, as brake fluid absorbs water and any cylinder that has sat for more than a few of years will no doubt have some rust issues. My cylinders, on my ‘52 which were replaced by a previous owner about 5 years prior, were pitted so bad I couldn’t hone them out.
Keep up the good work and keep us posted!
Phil
Project Journals
One of the last owners actually ran newer brake lines and replaced at least one wheel cylinder, so I'm *hoping* that won't be something I have to completely revamp as well, but we'll see I guess.
I got the throttle linkage hooked up today. I guess it's time to tell the neighbors to make sure their cars aren't on the street by my house, lol.
Got the driver door on today. It needs adjustment and bodywork, but it closes and latches successfully with the new latch. It has never been on the truck in the time that I have owned the truck because the lower hinge pocket needed to be replaced.
I also drove the truck around the block for the first time on 4/21/2021 (sans driver door, lol):
Page 1 of 2 1 2
