Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I have a 1953 GMC with a heater and I'm not sure of how it hooks up. There are 2 tubes that protrude through the firewall, one above the other. How do they hook up to the engine? Are the hoses a common size? Where is an on/off switch located? Any pictures would sure help. If I didn't screw up there is a photo of the heater attached.
