2 members (49 panel, Hotrod Lincoln), 42 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#1381894 10/23/2020 1:46 AM
I would like to install a 3rd brake light in my 53 3100. Something in the rear window, easily installed and doesn't light up the whole cab (reflecting) when its dark outside. Show me what you have, etc. Thanks.
Crusing in the Passing Lane
If you are using existing brake lights as turn signals, need to get it fixed so 3rd does not flash, I'm sure someone makes such a device.
Ed
2 Offline
It’s called a diode
You feed the center third brake light with two diodes
One feeding from each right and left lights
So if either side brake light is on, the center is on as well.
Identical diodes are almost always good to put in parallel to increase load capacity.
So pick up a handful of 1N400x or similar for about $1 and keep them around the shop
Think of them as check valves for current.
1N400x is the family, specific numbers are like:
1N4001, 1N4002, ...1N4006 etc
They are almost all rated for 1 amp each and the last digit is the reverse voltage capability
The end of the diode with the bar marking would be towards the center 3rd brake light on a negative chassis vehicle in the circuit I described.
-s
If the turn signals are the same bulb as the brake lights and you wire the third brake light with diodes, if you use the turn signal without the brakes on, the third brake light will flash with either turn signal. ONLY when you also have the brakes on with the turn signal will the third brake light stay on solid. The third brake light needs to be fed from a separate wire from the output of the brake switch BEFORE the flasher.
Go straight from the switch before it enters the signal box .
good planning is no substitute for dumb luck
Ex Hall Monitor
Ex Hall Monitor
This is the third brake light I rigged up on my 53. While it's not a truck a similar rig could be done on a truck. I used an old implement light housing. It's still 6 volt. I wired it to the downstream side of the brake light switch.
Another option is if you have a trailer receiver on your truck ,would just have to change to 6 volt
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
There are kits available to put lights in the ends of the bed rolls. Easily used for 3rd brake lights.
bed roll brake light examples
Sir Searchalot
Sir Searchalot
Agreed, no diodes or devices needed. (Ref: Tiny and John)
I have the bed roll lights that are tail lights, turn signals and brake lights.
Hey Mick53 where did you get those lights?
