I was recently troubleshooting a circuit at the bulkhead connector, and I decided to remove the windshield washer fluid reservoir for easier access. I discovered that a previous owner had simply ran a self-tapping screw through the back of the plastic jug, and into the firewall. With the reservoir removed, I could see that there is supposed to be a bracket to correctly hold the reservoir.
What I have is a plastic container, which looks like the one listed for 1962-1972. The bracket for that item doesn't match the threaded holes in my firewall. The two vertical holes look like the photos of a glass bottle and bracket, but that arrangement doesn't conform to the worn spot on the firewall. The shop manual is not helpful, so I tried google for photos with no luck.
Does anyone know what components I'm supposed to have?
Thanks!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1965 Corvair Monza Convertible
1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
