8 members (Wally / Montana, Steelonsteel, Tronman, 1955 1 Series, Bill Hanlon, Hotrod Lincoln, LAROKE, 1 invisible), 137 guests, and 3 robots.
Topics128,201
Posts1,057,279
Members48,466
Hey y’all,
I’m stuck on this one. I have a 1951 3100, swapped out the original 216 for a 1968 250. Does anyone have any suggestions on the radiator? Having a hard time finding hoses that will hook up to the original radiator.
Crusing in the Passing Lane
One could start with the original radiator, just have to search around to get the hoses to fit. If now using a pressure radiator cap, might overpressure heater core, might be worth putting a new vote there.
Ed
9
9 Offline
What thermostat housing are you using? I think the stock 250 thermostat housing layers over to the side. Summit sells a straight thermostat housing for a small block Chevy V8 that should work on your 250. Read the reviews. One guy claims to have used on a 1960 235.
https://www.summitracing.com/parts/sum-g3803
1953 Chevy 3600
1998 Dodge 2500 Cummins 12 valve
