3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13815 06/04/2003 12:13 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I have been looking for a higher ratio gear set for my 56 1/2 ton truck axle. A vendor at a swap meet tyied to sell me a car carrier with 3.55 gears he claimed fit. I did not buy his story or his part. What is correct will a 55-64 car gear set fit a truck? What is available for this rear end?
if it dosen't need fixed, break it
#13816 06/04/2003 3:06 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | never heard of any car gears fitting the truck - different type rears - the ratio avaiable for the task force is 3.38, the 3.55 is the one for the AD - check w/ Patricks Bill | | |
#13817 06/09/2003 3:25 AM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | I too have a 1956 truck(gmc) and wanted to say thanks for the referral to patricks.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
