1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
#13815 06/04/2003 12:13 PM
I have been looking for a higher ratio gear set for my 56 1/2 ton truck axle. A vendor at a swap meet tyied to sell me a car carrier with 3.55 gears he claimed fit. I did not buy his story or his part. What is correct will a 55-64 car gear set fit a truck? What is available for this rear end?
if it dosen't need fixed, break it
#13816 06/04/2003 3:06 PM
never heard of any car gears fitting the truck - different type rears - the ratio avaiable for the task force is 3.38, the 3.55 is the one for the AD - check w/ Patricks
#13817 06/09/2003 3:25 AM
I too have a 1956 truck(gmc) and wanted to say thanks for the referral to patricks.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
