| | | Forums66 Topics128,088 Posts1,056,396 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Hello all, I'm not sure if this is the correct area to be asking, but I'm getting ready to bolt the rear fenders to the bed. My question is, do the fender bolts get flat and lock washers, and hex nuts, or flat, locks and square nuts? Thanks in advance...Clint | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Chevy, 1950, 3800 Long bed, SRW. | | | | | Joined: May 2015 Posts: 11,091 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,091 | My '51 3100 had fender washers, lock washers, and hex nuts. I found very few square nuts on my truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Any suggestions as to where I can find the fender washers? | | | | | Joined: May 2015 Posts: 11,091 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,091 | Any suggestions as to where I can find the fender washers? Any hardware store should have them. They just have a larger OD than regular flat washers.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Thank you so much, I do appreciate it. | | | | | Joined: Nov 1995 Posts: 5,726 24601 | | 24601 Joined: Nov 1995 Posts: 5,726 | My fenders have never been seperated from the bedsides ('49 3804) -- I will take some pics this afternoon to show you what they look like if it isn't already OBE.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Sweet, Thank you John Milliman. | | |
