4 members (Johnny N, Otto Skorzeny, Forty9, Bill Hanlon), 108 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#1380736 10/14/2020 2:01 PM
[img]https://photos.smugmug.com/Cars-and...9d7d06/M/Charging%20System%20Types-M.jpg[/img]
There are two types of charging system used on these old cars and trucks (see diagram above, copied from an old Sun manual).
Type A uses a generator whose field is externally grounded. The generator in the Type B system is internally grounded. The reason I care is that test hookups for generator and regulator function are different, depending on the type of system in place.
As I understand it, to test which type you have, first measure resistance between Armature and Field terminals, and then between Field and Ground terminals. On the Type A system, the first measurement (A->F) will be lower than the second (F->Ground). The opposite will be true on the Type B system.
On my 1953 3100 truck, I have Generator #1100018, which is the 45 Amp 6-volt unit. When I measured resistances per the above, I got 1.8 Ohms (A->F) and 1.4 Ohms (F->Ground). This tells me I have the Type B (internally grounded) system in the truck.
So to the electrical gurus on the site, I ask: am I correct?
[btw: I don't seem to be able to directly post a photo, only a link to my SmugMug page. Not sure what I am doing wrong.]
1953 Chevrolet 3104 1/2-Ton
More pix
Photo posting instructions are in the left margin of every page. Only issue would be a too large file.
Riding in the Passing Lane
Gen. Motors & Mopar use type A & Ford uses type B.
George
1972 Chevy c10 Cheyenne Super
George:
That's what I needed. Much obliged.
More pix
H Online: Content
I've never seen a stovebolt charging system with a type B circuit, and I've been working on them since the late 1950's. The simple way to tell the difference is to look at the brush circuit at the back of the generator. If the field coil wire is attached to the armature output brush (the insulated one that goes to the ARM terminal of the generator) the generator is for an A circuit and it gets its ground at the regulator. If the end of the field circuit is attached to the grounded brush, or the generator housing, the generator is for a B circuit. The internal wiring of a B circuit regulator is also very different.
Thanks Jerry!
More pix
