2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#1380550 10/13/2020 6:02 AM
I need to find a replacement for my '95 lt1, (5.7L). Original got bent/broken...the dipstick is fine. I've looked at a lot of sites...no luck. Is this going to be a salvage yard item?
H Online: Content
Have you tried your local Chevy dealer's parts department?
Jerry...Yes...they don't have one that far back.
Did you look at the Ebay link I quoted?
Most likely the lower section of the tube is still in the block and will have to come out the TOP before a new tube can be driven in. To keep from pulling the pan to drive out from the bottom I made up a bolt with a slide hammer hook to pull one out from above. The inside of the tube has to be threaded with a tap so the puller bolt can screw in. Many times the tube will start turning in the block and upward pressure while turning will work it out.
Evan
Thanks everyone...the dealership DID have the tube. Installed.
