0 members (),
140
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I need to find a replacement for my '95 lt1, (5.7L). Original got bent/broken...the dipstick is fine. I've looked at a lot of sites...no luck. Is this going to be a salvage yard item? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Have you tried your local Chevy dealer's parts department? Jerry
| | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | Jerry...Yes...they don't have one that far back. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Did you look at the Ebay link I quoted? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Most likely the lower section of the tube is still in the block and will have to come out the TOP before a new tube can be driven in. To keep from pulling the pan to drive out from the bottom I made up a bolt with a slide hammer hook to pull one out from above. The inside of the tube has to be threaded with a tap so the puller bolt can screw in. Many times the tube will start turning in the block and upward pressure while turning will work it out.
Evan
| | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | Thanks everyone...the dealership DID have the tube. Installed. | | |
