3 members (ShopRag, 55shaker, Otto Skorzeny), 106 guests, and 0 robots.
Topics128,163
Posts1,056,920
Members48,458
Without disconnecting the battery cables what is the proper way to hook up a battery charger to a 6 volt positive ground vehicle? Positive charger cable to negative battery terminal? Or, positive to positive and negative to negative as you normally would. Battery Tender if it matters.
Positive to Positive. Negative to Negative. Dont worry about the vehicle system, just focus on the battery.
Yup to the above
Craig
