5 members (Hanks custodian, Phak1, Lostbuthaulinass, homer52, Wheelie), 138 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#1380246 10/10/2020 3:17 PM
Excerpt from the 47-54 Factory Assembly Manual . Can somebody tell me if the Hub Cover Assembly 3701357 is supposed to be on a 51 3100?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
As you know, the 47-54 Factory Assembly Manual is actually for 1954/55st Chevrolet trucks.
And, as you know, the steering wheel and the steering column changed in 1954.
And, as you probably know, the 47-53 Shop Manual does not show what is under the steering wheel (at the "joint between the steering column and the steering wheel).
You are asking the right question. Maybe someone will post a photograph?
Don't have a pic, but there's no hub cover assembly below the steering wheel on my '51. The steering column tube is straight from the bottom to the underside of the steering wheel.
If this helps, this is a '49. Doesn't look like any hub on this either. If it stops raining I can go out and take the cover off to get a better photo, I am hoping to drive it today anyway.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
All good info. Any idea why the horn blows without any steering wheel internals?
Crossover to the Horn Relay topic.
Same look as the 51. Thanks
Is the wire that runs inside the column removed as well? That could easily be shorted to ground. Woven insulation cover may be rotted away and the vinyl insulation brittle, cracked, and flaking off.
That wire is free and not making contact.
Couple more I just took of mine ('49), although it looks resolved.
OT Vehicles:
